• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    armster
    AutoCad Options File Reservations
    207 Views, 2 Replies
    08-30-2012 03:26 AM
    Good morning,
    I'm looking to implement a number of reservations using the ADSKFLEX.OPT file by setting up a number of groups or Projects for computers.  My query is:
    * Do you need to specify each version of AutoCAD, Revit etc.. so autocad 2011,2012,2013 or can I reserver 3 licensed for a HOST_GROUP to the AutoCAD suite? and Revit Strucutre Suites etc?
    RESERVE 3 ACD_F PROJECT HOST_SOMEGROUP  ?
    Please use plain text.
    Product Support
    Re: AutoCad Options File Reservations
    08-31-2012 06:22 AM in reply to: armster
    Yes you can specifiy the package name. It will reserve automatically for all the features within that package.
    RESERVE command can be against a feature or package.
    Please refer to this documentation for other commands if it accepts Feature or package
    http://www.globes.com/support/utilities/fnp_LicAdmin_11_11.pdf
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    Autodesk, Inc.
    *Expert Elite*
    TravisNave
    09-05-2012 10:57 AM in reply to: armster
    Keep in mind though that if you reserve 3 seats of the package, it will reserve 3 seats for each release, taking up essentially 12 seats.  However, you won't see this problem until a user who is not in the group tries to access a license when you have fewer than 12 seats total.  They will get denied and you won't know why until you understand this fact.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
