• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Active Member
    Re: AutoCad 2013 on Windows 8 bug - missing dialog boxes and can't close CAD
    02-05-2013 03:14 PM in reply to: alfred.neswadba
    oh sorry, I was reading about it before.. and the tip was to set it to 0 and then back to 1.. just to reset it in hopes that this is the issue.. the _saveas works by itself.. so the problem is with the dialbox box and that drop down arrow..  must be some osrt of WIndows 8 issue bevcasue it works toally fine in Windows 7.
    Please use plain text.
    Active Member
    02-07-2013 12:50 PM in reply to: vadim
    ok, a quick update.. so I did a complete clean uninstall and reionstall of CAD and it worked fine.. UNTIL.. I opened another drawing as a separate session of autocad (in other words, AutoCAD is running twice at the same time), and that broke it again... back to sqaure one.. so it seems it seem sthat "double" opening of AutoCAD causes this problem.. and now this bug is back even if I just have one instance of AutoCAD running.  :smileymad:
    02-07-2013 02:02 PM in reply to: vadim
    what happens if you login with another user account to your Windows?
    - alfred -
    Alfred NESWADBA
    Active Member
    02-19-2013 07:39 AM in reply to: vadim
    tried loggin in with a another user.. same hting.. so I know it's not the Windows Profile causing this..
    pendean
    02-19-2013 02:45 PM in reply to: vadim
    Goes back to the first reply: so far Windows 8 is unsupported and no official fixes exist.
    Sorry.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Active Member
    04-23-2013 08:14 AM in reply to: vadim
    I encounter the same problem on AutoCAD 2014 (yes 2014, not 2013) on Windows 8 x64.
    Description :
    - Start AutoCAD 2014
    - Open button
    - Click on the listbox on the up of open dialog
    - the only way is to kill the task in task manager
    I install all hotfix availiable on my AutoCAD 2014 and I have always the problem.
          Philippe
    05-06-2013 12:39 PM in reply to: vadim
    Same problem here with ACAD 2014 and Windows 8 64bit.
    05-06-2013 12:41 PM in reply to: pendean
    Same problem in 2014, which IS fully supported. Any ideas?
    Active Member
    05-06-2013 12:53 PM in reply to: cmadon
    Very strange on my notebook (HP EliteBook) :
    - outside the office, alone or with a projector, I have always the problem
    - in the office, on docking station, with a second screen connected, all work fine and I don't have the problem
    I don't understand !!!
    Philippe
    05-06-2013 01:02 PM in reply to: p.germanier
    do you have an Intel gc built in (2nd generation CPU) and parallel to it an ATI or nVidia?
    If so, try to disable the Intel one in the bios.
    - alfred -
    Alfred NESWADBA
