• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Active Member
    AutoCad 2013 on Windows 8 bug - missing dialog boxes and can't close CAD
    1395 Views, 35 Replies
    01-25-2013 10:47 AM
    Found a huge bug in AutoCAD 2013 running on Windows 8.. .. as  soon as you click on the drop down box of "Look In" when doing Save As, it breaks AutoCAD… after that you can’t get any dialox boxes, can’t save and can’t even close autocad without doing "end task" from Task Manager.
    Please use plain text.
    Distinguished Contributor
    KateMorrical
    Re: AutoCad 2013 on Windows 8 bug - missing dialog boxes and can't close CAD
    01-25-2013 11:22 AM in reply to: vadim
    AutoCAD 2013 is not currently supported on Windows 8.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
    Kate Morrical
    Digital Design Manager
    Washington, DC
    BIMmuse.com
    Active Member
    01-25-2013 12:11 PM in reply to: vadim
    yes, I am aware it is not supported as of right now, but I am sure eventually it will, and perhaps someone can find a work around in the meantime, not to mention, I am sure Autodesk engineers would love to hear about this problem before as I am sure Windows 8 will be embraced by thousands of users rather sooner than later.
    *Pro
    01-25-2013 12:48 PM in reply to: vadim
    vadim wrote:
    .... I am sure Windows 8 will be embraced by thousands of users rather sooner than later.
    I'm thinking that Win7 is going to hang on as long as XP did (and XP still is :smileyhappy: ).
    01-26-2013 08:16 AM in reply to: vadim
    What does the taskmanager tell you about how it's processor-usage of AutoCAD?
    When it hangs: what happens if you press <ESC>? If it's back then I guess your File-Dialog is just off screen, pressing escape does then close the dialog and bring you back to AutoCAD.
    What happens if you first set FILEDIA to 0? If you then try to do a _SAVEAS does AutoCAD hang now or does AutoCAD ask for the filename in the command-line? If that works do the save of the drawing one time to your local disc, then switch FILEDIA back to 1 and restart AutOCAD. (that helped me one time I had a similar problem).
    Do your test also after disconnecting your network-cable. I see Win8 a little bit sensitive with using network connections.
    - alfred -
    Edited by
    Discussion_Admin
    Alfred NESWADBA
    01-26-2013 01:00 PM in reply to: drjohn
    Could be, although I suspect Autodesk will introduce Windows 8 compatibility with AutoCAD 2014. Too much money out there to be made for Autodesk not to do so.
    Active Member
    02-05-2013 01:29 PM in reply to: vadim
    unfortunatelly,
    none of these tips worked... and the same issue on 2 different computers..
    02-05-2013 02:47 PM in reply to: vadim
    Interesting, so also with FILEDIA = 0 you can't save files?
    - alfred -
    Alfred NESWADBA
    Active Member
    02-05-2013 02:49 PM in reply to: alfred.neswadba
    nope.. it just freezes as soonas I click on that drop down arrow box to navigate to location where I want to save,... if I use the Computer icon on the left, and navigate through there it works fine, but if I use the drop down box, then it just freezes and I have to End Task it.
    02-05-2013 02:57 PM in reply to: vadim
    If you would have set FILEDIA to 0 you would have been asked for a filename in the command-line, there would not be any dialog nor any arrow box to navigate to any folder. Sorry.
    - alfred -
    Alfred NESWADBA
