• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2013/2014 DWG Format
    Distinguished Contributor
    AutoCAD slow
    210 Views, 11 Replies
    01-30-2013 05:37 AM
    When I am in AutoCAD almost every command I do may computer has to sit there and think for 20-30 seconds before it actually executes the command.  Would this have anything to do with our company server?  There are other coworkers that would have the same problem too but not as often as I would have the issue.  I think our server is running 2003.
    Please use plain text.
    pendean
    Re: AutoCAD slow
    01-30-2013 05:44 AM in reply to: jamied2000
    What are the PCs specs that you are running AutoCAD on? adn Windows version?
    WinServer2003 is not a supported OS to run the application and it's the worst OS to try and do work in with AutoCAD as it tries to manage your office's server/network/ email needs, if that is what you meant by your light post above.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Re: AutoCAD slow
    01-30-2013 05:57 AM in reply to: pendean
    Eash AutoCAD is on their own computer.  It is not on the server.  I have attached my pc specs.
    pendean
    Re: AutoCAD slow
    01-30-2013 06:07 AM in reply to: jamied2000
    Good systems: are the problems in certain files only, or in all files?
    What if you start a new file, commands are just as slow?
    Re: AutoCAD slow
    01-30-2013 06:11 AM in reply to: pendean
    It is pretty much every file.  Not sure on a new file.  Currently it is not doing it to mine but another coworkers started doing it.
    pendean
    Re: AutoCAD slow
    01-30-2013 06:12 AM in reply to: jamied2000
    "...started doing it..."
    So it's not constant and all the time, this is a recent observation (or sporadic)?
    Re: AutoCAD slow
    01-30-2013 06:14 AM in reply to: pendean
    Well it has been pretty constant for quite a while now.
    Distinguished Mentor
    braudpat
    Re: AutoCAD slow
    01-31-2013 01:34 AM in reply to: jamied2000
    Hello
    Have you some strange "ACAD.lsp" files created everywhere with your DWGs files ?
    Bye, Patrice
    rkmcswain
    Re: AutoCAD slow
    01-31-2013 04:23 AM in reply to: jamied2000
    You might give this a shot. The article is old and "Filemon" has been replaced by "ProcessMonitor", but the idea is the same. Let this tool monitor all file/registry activity while your AutoCAD is "sitting and thinking 20-30 seconds". There will have to be a clue in there as to what is going on.
    dgorsman
    Re: AutoCAD slow
    01-31-2013 08:00 AM in reply to: rkmcswain
    Also check your annotation scales, if you are not controlling them they tend to accumulate.
    Any third-pary applications and/or vertical products in use?  Referenced images?
    Adopt. Adapt. Overcome. Or be overcome.
