I have attached a video beacuse it is hard to describe the issue that I am experiencing.
When I use a point on an existing geometry as reference to place a new line or shape, I get a strange result when attemting to move either geometry.
As you can see in the video the two shapes will BOTH move when only ONE is selected.
Also, it seems that the shape/ lines that are not selected but still move are anchored somewhow which causes distortion.
Any info on this matter is greatly appreciated.
[center]
[img]http://vidbull.com/images/logo.jpg[/img]
[b]acad.wmv[/b]
[url="http://vidbull.com/4aj8tu1ban4h.html"]http://vidbull.com/4aj8tu1ban4h.html[/url]
[/center]
Solved by nestly2. Go to Solution.
It seems as though CONSTRAINTINFER is turned on. There is a toggle button on the status bar that controls whether Constraints are automatically applied as new objects are created. To delete unwanted Constraints, use the DELETECONSTRAINT tool on the RIBBON, the Geometric Constraints toolbar, or from the Command line.
