FATAL ERROR: Unhandled Access Violation Reading 0x0020 Exception at b0ba4c12h
Ive looked around the forums and cant seem to find a solution. I was running AutoCad on Windows 8 just fine before...
What are my options??
Thank you.
'Remove 8.1' seems to be the current solution for most: it does more than just add a start button.
Autodes Twitter Support seems to think removing all .NET and reinstalling only what AutoCAD needs is an option: worth a try if you have no deadlines due this morning.
Thank you.
there are several threads on windows 8.1 not working with any autodesk software
only fix is to roll back to windows 8 when it was working
DarrenP
My autocad mech 2014 (with SP1) works just fine/great with the new Win 8.1P.
With that kind of error message (on previous 8.0), the way i solve it is.... go to the "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AutoCAD Mechanical 2014 - English" folder and then run the "Reset Settings to Default - AutoCAD Mechanical" shortcut (your path/filename may slightly differ if it's not the Mech version). good luck...
did you install SP1? I had no problems running AC2014 on my notebook with new win 8.1. I installed it with automatic download of SP1 in the install options.
