• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    AutoCAD 2013 "Not Responding"
    2629 Views, 13 Replies
    06-07-2012 06:17 AM
    When i go to burst, explode and even some other commands, i am running into the program freezing up and saying "not responding".  Is anyone else having this problem and if so has anyone found a fix?  Gets kinda annoying and waste alot of time.  Thanks in advance.
    Please use plain text.
    B.OLSEN
    Re: AutoCAD 2013 "Not Responding"
    06-13-2012 01:52 PM in reply to: crabbygraphs
    Have no problem using "BURST" in regular Auto-CAD 2013.....
    But in Mechanical 2013 "BURST" is an unknown command....anyone know why that is? There are a few other commands that don't work in the Mechanical version...like "FLATTEN" and "ALIASEDIT" are a couple off the top of my head....
    Patchy
    06-13-2012 02:05 PM in reply to: B.OLSEN
    Definitely need to install Express Tools.
    B.OLSEN
    06-13-2012 02:25 PM in reply to: Patchy
    We all have express tools installed....went thru the whole add/remove features and added the express tools...but express tools pulldown still doesn't show up...
    Patchy
    06-13-2012 02:30 PM in reply to: crabbygraphs
    Go to Options, see if the path to Express is the right path.
    B.OLSEN
    06-13-2012 02:40 PM in reply to: B.OLSEN
    ....went thru the "MENULOAD" and found the acetmain.cuix and loaded that....express toolbar shows up now....but even if you use the pulldown...."FLATTEN" and "BURST" are still unknown commands....do we have a corrupted .cuix file?
    B.OLSEN
    06-13-2012 02:43 PM in reply to: Patchy
    where do I look for the express path?
    Customization files?
    Patchy
    06-13-2012 02:50 PM in reply to: B.OLSEN
    Mechanical has this problem, it stores the Express in the wrong place.
    Do this:
    Search for BURST.LSP and make a note of where the folder it is in
    Go to Option and just make a support path to that folder, restart autocad.
    B.OLSEN
    06-14-2012 06:05 AM in reply to: Patchy
    That did the trick....thank you very much!!!
    Patchy
    06-14-2012 06:25 AM in reply to: crabbygraphs
    May be someday Mechanical will get a HOTFIX.
