• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Active Member
    AutoCAD 2013 classic interface display using hatch issues
    1267 Views, 1 Replies
    10-11-2012 04:48 AM
    HI folks
    does any one know how to add hatches to finished hatches in the classic view of autocad.  in older versions if you needed to edit / add hatch you would double click on the hatch and the hatch dialog box would come up. then you would pick new points to add. i have no idea how to do this in 2013 cant find any answers on the web.
    Thanks in Advance.
    Please use plain text.
    pendean
    Re: AutoCAD 2013 classic interface display using hatch issues
    10-11-2012 05:18 AM in reply to: willtoner
    How old is "older"?
    What is double-click edting set to do with hatches in your CUI file? It should match what you had in the "older" version, HATCHEDIT command and nothing else. See screenshot to get you started, as you can tell, 2013 has QUICKPROPERTIES set there instead.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
