• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Valued Contributor
    Accepted Solution
    AutoCAD 2013 Hanging up on start - Loading Plug-in... ACDgnLsTrans.dbx
    500 Views, 11 Replies
    01-25-2013 02:16 PM
    Good morning,
    I just started getting this ssue with AutoCAD 2013 on DELL XPS 8300 with Windows 7 Pro.
    The loading screen will say "Loading Plug-in... ACDgnLsTrans.dbx"  and will hang on this for between 5 and 15 minutes.
    What is the solution to this problem?
    Thank you in advance for your assistance.
    Michael
    Please use plain text.
    *Expert Elite*
    Re: AutoCAD 2013 Hanging up on start - Loading Plug-in... ACDgnLsTrans.dbx
    01-26-2013 08:09 AM in reply to: mviscetto
    try to login to your workstation with another Windows-user account, this user should have (true) admin-rights, plus turn off antivirus software before starting AutoCAD.
    If you don't have a network-license also disconnect the workstartion from network (for this test).
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Valued Contributor
    01-29-2013 08:07 AM in reply to: mviscetto
    Solution:
    We added the identified file to the excluded file list in the AV profile.
    Most centrally managed Anti Virus programs have a “white list”.
    *Expert Elite*
    01-29-2013 08:20 AM in reply to: mviscetto
    thank you for your feedback!
    What AV-software do you use that blocks this file?
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    02-01-2013 03:19 PM in reply to: mviscetto
    Apparently I was mistaken
    I started experiencing the problem again and so I re-set ACAD back to default values and re-customized it item by item.
    All was great until I opened the XREF manager. It  took 1.5 mins to open the dialog box. once open I closed my acad session. I resatrted acad and sure enough it hung up on the AcDgnLsTrans.dbx file.
    There appears to be a problem with my xref manager.
    Any suggestions?
    *Expert Elite*
    02-01-2013 03:31 PM in reply to: mviscetto
    >> Any suggestions?
    Disable AV-software and try again?
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    02-02-2013 11:18 AM in reply to: alfred.neswadba
    That did not help
    It appears that it may nothing at all to do with AV.
    I ran the repair install and that did not help either.
    Valued Contributor
    02-02-2013 12:49 PM in reply to: mviscetto
    so I may have found a solution.
    I reset back to ACAD defaults and started over but this time I opened the XREF Manager (which works fine at this stage of the game) and left it open.
    I started re-building my customization and while I was mapping to my network drives it started again after I added my "FONT" folder.
    As long as I don't map to those fonts I'm good.
    I don't know why, it just is.
    At least for now.
    *Expert Elite*
    02-04-2013 06:15 AM in reply to: mviscetto
    interesting, what files do you have in this folder (at least what file-types?).
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    02-14-2013 07:52 AM in reply to: alfred.neswadba
    The folder contains 467 items and is 321 mb
    82 .shx files (6 mb)
    10 .fon files (249kb)
    1 .otf file (41kb)
    1 .pfb file (27kb)
    1 .sitx file (96kb)
    8 .ttc files (hmmm these equal 125 mb)
    364 .TTF files (188mb)
