• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    AutoCAD 2013 Access Error
    1205 Views, 3 Replies
    07-01-2012 04:46 PM
    I was using the program the other day when I decided i would leave it running over night (just turned my monitor off) while I was sleeping with the intention of getting back to work on a project I was really into. When I woke up and got back on I saw a message had prompted in the program saying "FATAL ERROR: Unhandled Access Violation Reading 0xfffffff8 Exception at ef63241ah"
    I Tried restarting my comp., reinstalling the program, running it as administrator, and uninstalling it then installing it back again and this message still continues to appear right after I open the program. (It gives me the option of only clicking ok at which point it aborts or shuts down the program imidietly, leaving only a report to fill out and send. (which of course i have already done twice)
    I had no choice but to install and use the 2012 version which thank goodness hasn't had the same issue but now I can't open the dgw I had worked on for 4 days straight. I'm fine using the older version but still don't get why this happened.
    If anyone has any ideas or help they can give I would really appreciate it, Thank you
    Please use plain text.
    Product Support
    Re: AutoCAD 2013 Access Error
    07-02-2012 08:15 AM in reply to: amasso
    I managed to find your error reports in out database and it looks like this could be related to a corrupt graphics cache.
    Please try the following and let me know if it helps:
    In Windows Explorer, navigate to the "GraphicsCache" folder:
    Depending on your operating system, the path would be something like this:
    Windows XP
    C:\Documents and Settings\<username>\Local Settings\Application Data\Local\Autodesk\AutoCAD <product name>\R19.0\enu\GraphicsCache
    Windows 7,
    C:\Users\<username>\AppData\Local\Autodesk\AutoCAD <product  name>\R19.0\enu\GraphicsCache
    Delete all files named *.AcDsGcCache.
    Restart your machine and try to start AutoCAD 2013.
    Does it start correctly now?
    Best regards,
    Silvia
    Silvia Menon
    Support Specialist
    Product Support
    http://www.autodesk.com/autocad-support
    ________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This will help everyone find answers more quickly.
    Member
    07-02-2012 02:58 PM in reply to: Simenon
    Dont suppose you can link me a guide of some sort to help me through it? I'm having trouble finding the folder (I have windows 7) I tried searching it in the search programs and files and looking through my program files folder but nothing.
    Member
    07-02-2012 03:21 PM in reply to: Simenon
    Wow I figured it out, turns out it was a hidden file I had to "un-hide". Thank you so much for you reply and help. I really appreciate it. So glad to have my 2013 version up and running again. I'll make sure when or if the time comes to pay it forward. Thank you again.
