AutoCAD 2013/2014 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Attribute text not displaying
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello - I have a client with an issue I cannot figure out...
They have one file xrefed into another but the text is not showing up. It is a block and the text is an attribute - but it is exploded.
I have attached 2 images - the first one - of the original file the second - where it is xrefed into another file with the text missing.
Any thoughts??
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: lisa@kalblue.com
Re: Attribute text not displaying
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What if they "BURST" instead of exploding the attribute?
Windows Vista Business
Service Pack 2
Intel(R) Core(tm2) Quad 3.0 GHz
4.0 GB RAM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That might be the source of the problem as some people try to use attribute-definitions to place text within a drawing. The bad thing is that it works, they can start ATTDEF, and write the text .... but this written text is then the name of the attribute-definition.
As long as you leave the object like it is it looks like a text-info, but (and now the bad way starts) don't use this drawing with that attribute-definitions within any other drawing. In case of e.g. _INSERT this drawing into anohter one the attribute-definitions are part of the inserted block, but then they show up the values of the attribute ==> and the values are empty, the name of the attribute is not any more written down like a text. (hope that is clear described).
Either you have a tool that converts attribute-definitions to text-objects or you don't insert this drawing into any other one .... or you tell the guy who used attribute-definitions instead of text that he/she has to repair that.
HTH, - alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Attribute definitions (outside of blocks) don't show up when their host file is xrefed. They have to be part of a block definition to be visible.
A fix I saw suggested on another forum is to make a temporary block from the attributes and then use BURST to convert them to text.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I had trued just the burst and that did not work - creating a tempoary block and bursting that worked.
Thank you all for your help!
LD
