• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    New Member
    Absolute and Relative Coordinates
    361 Views, 2 Replies
    10-13-2012 02:57 AM
    I want to switch to relative coordinat input without using @. How is this done?
    I have tried to change the settings in the Snap dialogue box, under Dynamic Input, where I have clicked on the Pointer Input, and the  I have marked the Cartesian Format and the Relative coordinates.
    But it doesn't work. Any suggestions, please?
    Please use plain text.
    *Expert Elite*
    Re: Absolute and Relative Coordinates
    10-13-2012 08:12 AM in reply to: liz.helen.rosenkilde.christensen
    After setting dyn up, did you turn on dyn?
    Active Member
    10-13-2012 10:27 AM in reply to: liz.helen.rosenkilde.christensen
    Liz,
    With Dynamic Input turned on, all you have to do is hit the TAB key to go between the different input areas. If it is set to relative, all of the values that you type in are relative to the last point. If it is set absolute, then they are absolute to 0,0. I usually leave mine set to Polar input because I use that most often. To switch to coordinate input, I just type a comma after the first number entered and then type in the second number (and third if 3D). The first becomes the X value and the second Y.
    Hope this helps,
    Jeff
