• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    ACAD '13 Save as, click shortcut folder, opens explorer window
    235 Views, 1 Replies
    06-18-2012 09:47 AM
    Howdy,
    One of our stations is doing something odd, but not unreasonably difficult to work around.
    Hopefully just as easy to fix.
    AutoCAD 2013 single server license on a 32-bit Win XP.
    When we have our file open, then select Save As, the dialog box opens fine.
    Then, we select a shortcut folder and instead of going to that location inside the dialog box, it opens a new Windows Explorer window at the location. If we go back and right-click the shortcut folder in the dialog box, "Select" is the bolded first option. "Open" is the second, normal option. When we select "Select," nothing happens. When we select "Open," it opens the window externally.
    We would like to be able to navigate shortcuts inside the dialog box. Please tell me if you need more information.
    We can save in My Docs and move the file, but it would be nice to fix this ASAP.
    I am running ACAD '13 on a Win7 64-bit and am not having this problem.
    Please use plain text.
    TravisNave
    Re: ACAD '13 Save as, click shortcut folder, opens explorer window
    06-18-2012 10:13 AM in reply to: Patron_Vectras
    Check your Windows Explorer settings to make sure that you do not have to checked to open each Explorer folder in its own separate Windows process.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
