• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    Accepted Solution
    ACAD '13: Quick Properties not recognising objects when selected
    1496 Views, 9 Replies
    08-06-2012 10:58 PM
    I'm having a minor issue with Autocad 2013 at the moment. I use the Quick Properties box to change a lot of my object properties, but since changing from 2012 to 2013, I have noticed QP doesn't recognise the selection of any objects. I have attached a screenshot showing what I mean. Anyone else had this issue and successfully resolved it?
    Please use plain text.
    *Expert Elite*
    Re: ACAD '13: Quick Properties not recognising objects when selected
    08-09-2012 11:46 PM in reply to: murdan35
    if that happens in all drawings with all type of objects I saw (for previous AutoCAD releases) that a repair-installation had helped in most cases.
    May be resetting the AutoCAD profile also helps (to be found in Windows-Start-menu ==> Autodesk ==> AutoCAD 2013... ==> there you find the option). But make sure to first save your current profile and workspaces!.
    But check first other drawings and other element-types.
    Good luck, - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Member
    08-22-2012 06:44 PM in reply to: alfred.neswadba
    I tried the repair install when I got the chance, to no avail. It happens for all objects in all drawings that I open. One of my workmates is adamant that there is an option somewhere in the program that causes this, but he can't remember any details of the fix or command etc.
    It's not a huge issue as I just keep using 2012, but I like using the latest if it is on my computer, so it's a bit annoying.
    Active Contributor
    08-22-2012 08:39 PM in reply to: murdan35
    looking at your screenshot, the quick properties dialog is not displayed. The Properties palette is however.
    I'm not sure I understand your issue. Is it the Properties palette is not showing the object type or the quick prop dialog is not being displayed when you select the object?
    Craig.
    Member
    08-22-2012 09:47 PM in reply to: oohaah
    Yeah, properties are not displaying in the pallette. They don't appear in the Quick Properties popup box either when I have that turned on. Bit of an odd one, it seems like the objects aren't recognising to display the properties. Happens to any object I select.
    Active Contributor
    08-22-2012 09:51 PM in reply to: murdan35
    Can't say I've come across that before. I don't know of any setting or variable to turn that function on or off. I would expect it to be part of the architecture of the software...
    Sorry mate can't help:smileysad:
    Active Contributor
    08-22-2012 10:03 PM in reply to: oohaah
    Member
    09-12-2012 05:49 PM in reply to: oohaah
    Cheers mate, I've fixed two of my firm's machines with that fix. Not sure which part helped (the uninstallation of Navisworks or the full repair install of Autocad), but the voodoo worked!
    Active Contributor
    09-12-2012 06:58 PM in reply to: murdan35
    Glad to hear
    New Member
    10-01-2012 01:45 PM in reply to: oohaah
    That was weird, I did the repair and that appearantly did nothing, I tryed shutting down AutoCAD a few times with no luck, so I turned off my computer and left for the day. But I come in on Monday and the prpperties magically appreared. makes no sense, other that me running a bunch of legacy lisps from older versions of AutoCAD causing the problems.
    But I still can't publish or plot in the backgroung. it just says publishing job forever. has anyone had this issue?
    But thanks a lot for all your help everyone!!!!
