• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Active Member
    Accepted Solution
    3D trim newbie! help!
    228 Views, 8 Replies
    10-05-2012 08:41 AM
    Hi! i'm a Autocad 3D newbie! Have some problems to figure out how to trim a solid from a sphere. well here's an image that will explain better!( it's the pink part from the green)
    thank you so much !
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: 3D trim newbie! help!
    10-05-2012 08:44 AM in reply to: nicole.ravasini421
    Trim doesn't work, use SUBTRACT
    Active Member
    10-05-2012 08:45 AM in reply to: Patchy
    the subtract command subtracts the whole pink solid and leaves the empty shape in the sphere, I just need to cut the part that sticks out from the bottom of the sphere!
    *Expert Elite*
    Patchy
    10-05-2012 08:52 AM in reply to: nicole.ravasini421
    Attach your drawing here.
    Active Member
    10-05-2012 08:55 AM in reply to: Patchy
    *Expert Elite*
    Patchy
    10-05-2012 09:56 AM in reply to: nicole.ravasini421
    Subtract command.
    Active Member
    10-05-2012 10:05 AM in reply to: Patchy
    thanks!!
    but how did u do it? subtract and?
    *Expert Elite*
    Patchy
    10-05-2012 10:15 AM in reply to: nicole.ravasini421
    Thanks for the challenge, it was not as EZ as I thought.
    I had to make a copy of the model, SUBTRACT the unwanted parts, then SEPARATE them, after that I move them back to the original position.
    Active Member
    10-05-2012 12:03 PM in reply to: Patchy
    Thank you!!! gonna try to repeat it myself, gotta learn!!!!
    thanks again!
