• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Distinguished Contributor
    jz4all
    Accepted Solution
    3D drawing, Views in viewports not stable?
    295 Views, 7 Replies
    01-07-2013 02:32 AM
    I have 3D drawing. I put camera's in several places and situations. In viewports I choosed a camera in every viewport. They work nice so long the drawing is open. When I close the drawing after saving it ofcourse. When I open it again , the viewports jump to SOUTH-EAST. and I have to rearrange the view of the cammera again. Although I used the command UCSFOLLOW to solve this, but it did not work.
    PS. that happens only in the viewports which based on camera's. The views in other viewports which are not based on camer's, stay without chaning or jumping.
    Any idea how to solve this?
    Jaf
    Please use plain text.
    *Expert Elite*
    pendean
    Re: 3D drawing, Views in viewports not stable?
    01-07-2013 06:00 AM in reply to: jz4all
    I've not tried it, but does locking the viewports help?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    jz4all
    01-07-2013 06:52 AM in reply to: pendean
    The view ports are locked.
    Eee the attachements. The first before closing and open again. The second after evry time opening .
    Jaf
    Product Support
    01-09-2013 06:25 AM in reply to: jz4all
    Hi Jaf,
    Do you mind sending the file or part of it?
    Does it also happen with a new drawing created from scratch?
    Cheers,
    Luciane
    Luciane Conceição
    Product Support Specialist
    Autodesk, Inc.
    jz4all
    01-10-2013 01:30 AM in reply to: luconceicao
    Thanks for your response.
    Although I used (among others) the following operations:
    • Delete all layers filters.
    • Delete unnecessary layers
    • Delete all xrefs.
    • Delete JPEG picture
    • Savefidality to 0
    • Savepercent to 0
    • Reset scale list
    • Pu all, and  -pu ( for R & B)
    • Audit
    • Begin from scratch.
    • Save the file to a higher version than 2004
    • Save to DXF and turn to DWG
    All these did not reduce the file size (29 MB). And did not speed the file. And did not solve the problem of the viewports as I explaned previously.
    What did I miss? I don't know.
    I  tried to send it here as e-tansmit to reduce the file size to 19 MB!! But it could not because of file size limitations.
    Product Support
    01-10-2013 06:12 AM in reply to: jz4all
    I will create an FTP site and send the login details in a private message.
    jz4all
    01-11-2013 06:42 AM in reply to: luconceicao
    Thank you Luciane,
    The Problem is solved, in the meaning that, I believe, the reason is not in the AutoCAD, but in my PC.
    I opened the file in another PC, the viewports reacted normal and stable.
    I opened again the file in my PC, the problem continued. I repeated that again and again, I got the same result.
    May because of the graphic card. Of another reason. Have you an idea?
    My PC uses Windows 7, Ram 8 gb, Graphic card NIVIDIA.
    The other PC in which the viewports responded normal, uses Window 7 Ultimate, Ram 12, and another sort graphics card.
    I'll ask also the ICT-helpdesk in the company to solve it.
    thanks again.
    Jaf
    Product Support
    01-11-2013 07:31 AM in reply to: jz4all
    Hi Jaf,
    I am glad to know that you are on the way to find a resolution.
    I think it is a good idea to check if the graphics card drivers are updated, you can download supported/certified versions from:
    http://www.autodesk.com/autocad-graphicscard
    It may also be worth reinstalling the program, just in case.
    I hope you can have this issue resovled soon, let us know if you need anything else.
    Cheers,
    Luciane
