• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2013/2014 DWG Format
    Distinguished Contributor
    0,0,0 point
    210 Views, 4 Replies
    12-06-2012 03:50 PM
    I recently have this problem in certain 2d DWG files.
    The 0,0,0 is different when I try to locate where it is.  It keeps giving different point in the file.
    What's causing this problem?  Thanks in advance.
    Please use plain text.
    Active Contributor
    Re: 0,0,0 point
    12-06-2012 04:51 PM in reply to: diesellam
    It is porbably becuase you have the dynamic input on and it is always doing relative.  try turning dynamic input off. F12 should be the hotkey to toggle it off and on.
    _________________________________________________________________
    KarelCAD Application Support Specialist
    Re: 0,0,0 point
    12-06-2012 11:22 PM in reply to: diesellam
    How do you recognize/verify that the origin "is different"? ....different to what? To your current view or in relation to an object? What is the reference you use while verifying that?
    Another option may be you have created a UCS with another origin.
    - alfred -
    Alfred NESWADBA
    Re: 0,0,0 point
    12-07-2012 08:40 AM in reply to: diesellam
    Check your INSBASE system variable. Make sure that's set to 0,0,0 as well (gets changed when you wblock something out). Not sure if that's what's going on because I'm not sure if I understand your question correctly.
    "The source of expertise is not in the memorization
    of the minute details of a subject but in the thorough
    understanding of the fundamental concepts on
    which it is based." - Dan Appleman
    Re: 0,0,0 point
    12-07-2012 08:50 AM in reply to: diesellam
    I think the F12 does the trick, now the 0,0,0 is correct.
    What I meant is when I draw a line, starting at 0,0,0, it doesn't snap to the intersection of the X,Y axis, but rather some randome point close to it.  It just happened in this file for some reason.
    I want to make sure the structural grid is the same on every floor (relative to the 0,0,0)
    Thanks all.
