Well, it is not always the same, that's why there are crossing vertical lines representing markers. On every crossing along the line I need to paste one object ( a circle with a line connecting it to the crossing ) exactly paralel on the vertical line with the ref point on the crossing.
I hope you could follow me, tnx
Based on your last message, it sounds like you're looking to PLACE the markers.
So I'll re-ask Dean's question: HOW would the macro decide WHERE to place these? When you do it manually, how do YOU decide where to place them?
Don Ireland
Engineering Design Technician
So I should place the markers first ? I never used markes..
When I do it manually I copy with a ref point and then paste every 50-60 m where the vertical line crosses the main line ..
There is no autocad element called a "marker". But the script will need SOMETHING tell it where to put these lines. You can't tell it to put them "every 50-60 feet". You could tell it to put them "every 50 feet", "every 53 feet" or any other number you come up with. But a computer program needs to be told hard numbers -- or HOW to compute those numbers.
Don Ireland
That's why i don't know how to use them I guess 😄
Well, the problem is the distances are random, so that won't do as a marker. I am triing to find a way how to tell autocad : Put X with orientation Bn on every crossing of line A with the line Bn ?
