AutoCAD Forum
wipeout frame selection
3 REPLIES 3
MKH-VB
1595 Views, 3 Replies
i have a question about wipeouts.  I have just upgraded to acad 2014 from 2011.  Now in 2014, I can turn off wipeout frames, but if my mouse crosses over one, it highlights so I can select it.  How do i turn that off?  I don't want the frame to highlight unless i select it. thanks
mkh
3 REPLIES 3
rkmcswain
in reply to: MKH-VB
Do you mean "hover" over it and it displays, or make a selection over one and it picks it up?
If the latter, see this
R.K. McSwain     | CADpanacea | on twitter
edwin.prakoso
in reply to: MKH-VB
There is no variable that can control wipeout frame highlight. The only way to prevent that frame from being highlighted is to move it to 'wipeout layer' and lock the layer.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
MKH-VB
in reply to: rkmcswain
frameselection was the key. Thanks
Mike
mkh
”Boost
