i have a question about wipeouts. I have just upgraded to acad 2014 from 2011. Now in 2014, I can turn off wipeout frames, but if my mouse crosses over one, it highlights so I can select it. How do i turn that off? I don't want the frame to highlight unless i select it. thanks
Solved by rkmcswain. Go to Solution.
There is no variable that can control wipeout frame highlight. The only way to prevent that frame from being highlighted is to move it to 'wipeout layer' and lock the layer.
