How come sometimes after creating viewports with the red border after working on my drawing all of a sudden if I double click in one of my red viewports a black border comes up surrounding all my viewports and makes then entire back ground of the whole page one big viewport? I have attached an example.
Solved by sthompson1021. Go to Solution.
Solved by pendean. Go to Solution.
It sounds like you are double clicking on the VP border which starts the VPMAX command.
I have other viewports that I want to modify but when I try to I get the big balck border around everything and instead of editing an individual viewport it access the background.
ok so I see a VPMAX tab at the bottom, how do I get out of that and back to model and paper space?
You actually have three viewports in the layout. The 2 red ones and then the outer solid white line is one too. Click on that and erase it and everything should work ok.
I just figured out that to when I put in a title block I can just draw a rectangle around my page to creat my own border,.
Thanks for the help. I worked out well
I will continue to use your suggestions.
