hi everyone
i am leonardy from indonesia. im using autocad 2014. can you give solution to my problem?
my problem is very slow when i try to open my file, even now i cant open it ( i wait from 8 hours and it still not open).
my file size is 62 mb, it is factory project, the object in that file is already assign material in it. at first still smooth when open and working it but it become harder and now i cant open it.
and another file above 30 mb at least i need to wait half hour to open it
and i think my computer specsification is good so i wonder why this is happen
here is my computer specification:
HP Z420 600W 90% Efficient Chassis
Intel® C602 Chipset
Windows 7 Professional 64bit OS
Intel Xeon E5-1620 3.6 10M 1600 4C CPU
4GB DDR3-1600 ECC (2x2GB) RAM ( already upgraded to 16 gb)
NVIDIA Quadro 600 1GB Graphics
HP 500GB SATA 7200 1st HDD
can you help me with solution for this? is the problem in the autocad?
thank you for your attention.
Solved by Alfred.NESWADBA. Go to Solution.
Solved by braudpat. Go to Solution.
i update my latest computer specification:
i upgrade my RAM ,VGA and hard disk.
16 GB RAM
AMD radeon R9 280X 3GB 384Bit DDR5
SSD harddisk
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
Q1) Have you installed the SP1 for ACAD 2014 ?
Q2) Have you MANY strange Linetypes loaded ?
If YES, you are facing to the "DGN Linetypes" problem !
==== General Procedure to purge/filter DWGs ====
- Please open your DWG in RECOVER Mode
- Go back to Model Space
- PURGE+PURGE
- CANNOSCALE = 1:1
- SCALELISTEDIT and try to erase all possible scales except the 1:1
- ReSave / Quit / ReOpen
You have to do this first with ALL your XREFS DWG and last with the Main DWG ...
Waiting ...
Patrice BRAUD
and to try some other options for cleaning/repairing the drawing:
What you can try with your system:
Good luck, - alfred -
Are you only having problems opening AutoCAD files (where there is a long delay)? Or do you see this to some extent with other programs too?
Do you ever clean your TEMP folders or registry? If not, a fairly safe program to use is CC Cleaner. There's no guarantee this will help, but if you don't do this type of system maintenance on any kind of regular schedule you might want to try it and see if it makes any difference.
It's more likely the problem you have is in your AutoCAD file(s) somewhere. But it never hurts to eliminate all the other possibilities.
Good luck!
Dave
sory for the late reply.
thank you guys for your solution. i'm using xref and it works fine.
thank you
