I mistakenly pressed docked, and the whole tool bar is gone, don't know how to get it back.
I get back some of the ribbon by typing command: ribbon
however, the main tab come back, but not the sub title.
Command CUI
Expand Workspaces.
Highlight the desired Workspace.
Expand Toolbars in the left pane.
In the top-right pane is a button called "Customize Workspaces". Select that.
Check the desired boxes in the left pane.
Select the "Done" button.
Apply.
OK.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Switch to a different workspace (something other than Drafting and Annotation) and then switch back. It should come back if you're using the default workspace save settings.
