Not sure how to explain this but here is goes. I have for example 2 lines in a drawing. One on the x axis and one on the y axis. The x axis line does not touch the y axis line because the y axis line comes short of the x axis line. I want to trim the x axis line to where this y axis line intersects it but do not want to extend the y axis line to touch the x axis line. When I upgraded to 2014 it will not do this anymore. Is there a setting that i need to change? I have never had to change any settings before for me to be able to do this. I hope this is understandable explanation of what I am trying to accomplish.
Solved by Kent1Cooper. Go to Solution.
[I'm not sure whether it may be different in newer versions than mine, but check the EDGEMODE System Variable -- set it to 1 if it's 0, or set it within a Trim or Extend command, after selecting boundary objects, with the Edge option.]
@helenhih2o wrote:
Wow, thanks! I was struggling with this too. Is there a place where all these system variables are listed, with definitions/purposes. I have no idea what EDGEMODE means.
Help should tell you about any specific System Variable [for which they are willing to reveal the details -- there are some undocumented ones]. Type its name into the Search window. Back in ol' 2004, there was a place in Help with a handy alphabetical listing of all System Variables, but I'm not sure it's as easy as that in some newer versions [I'll have to check when I'm next where I have 2015 available].
