i using auto cad 2014 registerd version in model which solid polyline i crete than one when i check in layout that is blank
Solved by jivkomitev2. Go to Solution.
Do you mean you cannot see the polyline?
If so make sure it's not on a layer which is frozen in that view port.
To test that, create another viewport and see if you can see your polyine in the new viewport
Howard Walker
check if in viewport in your layout visual style is set to "hidden line" instead of "2D wireframe"
also in the properties of the viewport - "Shade plot" should be "2D wireframe"
