iam using AutoCAD 2015 when i using simplex.shx font name
when i add new single line text to paper space i have this problem see picture (no in model problem)
but when i going to edit it , i don't found any problem see picture
but when i Regenerating model. the proplem appar agian
what can i do to solve this problem
Solved by Amremad. Go to Solution.
can you upload that DWG?
- alfred -
No such problem here, see attached: did you "migrate" from an older version or perhaps your simplex font is missing?
check the date on your SIMPLEX.SHX file (the one that's actually being used). There are a couple of version floating around that have been distributed by Autodesk. The older one is not a Unicode font, the version dated 2004 is. Ensure you're using the current version.
>> try put your text in paper space
No problem, also in paperspace. Do you speak about TEXT or MTEXT?
Can you recreate that in a new drawing? If so, upload it, I guess it's drawing specific or just your installation. To make sure which of those 2 possibilities we need a drawing to try your drawing on different systems.
- alfred -
hi every one
thanks for all about trying helping me , i found my solution of this problem
first see this picture
the problem happen when i use the arabhol.shx with bigfont , but when i delete it or uncheck use big font the problem disappear ,
i think AutoDesk must fix this debuge becouse i think this problem will happen with another fonts , i will attach the sample of the problem and its fonts but must move the fonts to autocad folder font.
thanks for all
