my AutoCAD 2014 dictionary is marking most of the text in a drawing as spelled wrong.
any ideas on what may cause this to happen?
how can i fix this and have my 75 users also fix the file on thier pc's?
Solved by pendean. Go to Solution.
Just found your workaround but it seems to not work on my end. When I am setting the DCTCUST system variable to point to a text file with .cus as extension and containing a list of words separated by newlines nothing is displayed in the Dictionary window (where the list of words normally gets displayed).
Any ideas as to what I might be doing wrong? The same file is imported fine to an existing working .cus file.
Thanks in advance for any input.
Teodor Constantinescu
System specs: AutoCAD 2016 64-bit, Windows 7 64-bit SP1, Dell Inspiron 5520 with Intel Core i5-3210M, 8GB RAM, Intel HD 4000
