Good morning,
which is the variable that controls the appearance or not of the "object snap" in dimension entities? It happened that on a particular workstation these do not appear and do not know as placement.
Thank you very much!
Solved by Alfred.NESWADBA. Go to Solution.
Only possible with AutoCAD 2015, and there the sysvar is called OSOPTIONS (>>>details<<<).
- alfred -
Dear Alfred, good morning.
It happened on a workstation with a version prior to 2015, but I see that this is the solution! Thank you very much!
Well, the releases prior to 2015 could not differentiate between a line from a dimension and any other line-object. So in 2014 and earlier dimension lines are always found by objects snaps.
What is new with 2015 is that you can tell the object snap NOT to find the dimension lines.
- alfred -
