AutoCAD Forum
"object snap" in dimension entities
3 REPLIES 3
emaiolino
519 Views, 3 Replies
Good morning,
which is the variable that controls the appearance or not of the "object snap" in dimension entities? It happened that on a particular workstation these do not appear and do not know as placement.
Thank you very much!
Esteban Maiolino
Titular EMBA Proyectos
Sitio web o nombre del blog
Facebook | Twitter | LinkedIn
3 REPLIES 3
Alfred.NESWADBA
in reply to: emaiolino
Only possible with AutoCAD 2015, and there the sysvar is called OSOPTIONS (>>>details<<<).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
emaiolino
in reply to: Alfred.NESWADBA
Dear Alfred, good morning.
It happened on a workstation with a version prior to 2015, but I see that this is the solution! Thank you very much!
Esteban Maiolino
Alfred.NESWADBA
Well, the releases prior to 2015 could not differentiate between a line from a dimension and any other line-object. So in 2014 and earlier dimension lines are always found by objects snaps.
What is new with 2015 is that you can tell the object snap NOT to find the dimension lines.
- alfred -
Alfred NESWADBA
”Boost
