Previously i had the 2014 Professional suite installed on my computer without issue, but ever since i upgraded to the 2015 Ultimate Suite i can no longer preview dwg files in the windows explorer.
This is very frustrating as i often need to look at older drawings which don't have descriptions in the title. Is there an option i need to tick somewhere?
Hi Alex,
Please try the followings:
Make sure all DWG and BAK files are set to open with an AutoCAD Application or AutoCAD DWG Launcher:
Install the version of DWG TrueView that corresponds with the latest version of AutoCAD installed:
Make sure the drawing file is set to save a thumbnail preview image:
