Is there a way, from the command prompt, to quickly bring up help for a single, known command? For example, something like "CIRCLE -?" to bring up the syntax and options for the CIRCLE command?
Solved by Alfred.NESWADBA. Go to Solution.
after you typed in CIRCLE<ENTER> press <F1>.
- alfred -
Another option is to hover over the command icon on the Ribbon and press F1. A prolonged hover brings up a quick tip. F1 while hovering opens the help system for the particular command.
Dave.
