hi
i ve got one question please:
i would like to draw in autocad 2013 something like mesh or foam, but i don't know if it's possible, and how ?
draw it and extrude it, i would like it in 3d dimension.
thanks
Solved by Patchy. Go to Solution.
i post with the dwg, for your understanding
thanks again
ps: it 's to analyze this part after with cfd in 3d
@fredpied wrote:i post with the dwg, for your understanding
thanks again
If you need a 3D solid and you're talking about the honeycomb hatch portion, here's what I did:
EXPLODE the hatch, Use REGION command and select the exploded hatch, then use EXTRUDE command.
