AutoCAD 2013/2014/2015
Member
Message 1 of 8 (706 Views)
problem installing autocad 2013 student version
706 Views, 7 Replies
03-23-2013 10:19 AM
when i installed autocad 2013 student version i got the following message:
Some files could not be created.Please close all application,reboot windows and restart this installation.
after doing so it again shows the same message . Installation log file is attached .
basically i got this message in the log file.
Extracting autorun.inf
Cannot create autorun.inf
*Expert Elite*
Message 2 of 8 (684 Views)
Re: problem installing autocad 2013 student version
03-23-2013 11:31 AM in reply to: vaibhavgpt116
Try the Download with browser rather than the autodownloader/installer.
Turn off UAC and anti-virus before installing.
(since you have already tried installing you might need to search Google for Autodesk Clean Uninstall instructions before doing the re-install)
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Member
Message 3 of 8 (625 Views)
03-25-2013 07:50 AM in reply to: JDMather
i've downloaded from browser.i tried installing again after deactivating antivirus but it didn't worked
*Expert Elite*
Alfred.NESWADBA
Message 4 of 8 (622 Views)
03-25-2013 07:53 AM in reply to: vaibhavgpt116
what are your system specs? (including OS)
And can you upload your install-logfile? So we can see what files are missing or could not be created.
At least in your first post it told you that you had to reboot and then start the installation again. Had you rebooted? Had you tried to start the setup with right-mouse-click and "run as administrator".
BTW: do you have admin-rights?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Member
Message 5 of 8 (600 Views)
03-25-2013 11:37 PM in reply to: Alfred.NESWADBA
I ve attached log file here.i rebooted when it asked so. i ve also tried installing as administrator.it didn't worked.
here are my system properties:
*Expert Elite*
Alfred.NESWADBA
Message 6 of 8 (596 Views)
03-25-2013 11:52 PM in reply to: vaibhavgpt116
you should first update your Windows, there is a service pack 1 out there + a lot of hotfixes you get installed with the Windows-Update functionality. That might be one possible solution.
Next: in your log it can't extract all files, try first to download the exe (I guess it is an exe) from the Autodesk server, then copy it into a temp-folder on drive C: and use WinZIP or WinRaR or 7Zip to uncompress the EXE like you would do that with a ZIP-file. After that start from this new unextracted files the setup.
Good luck, - alfred -
Alfred NESWADBA
Member
Message 7 of 8 (595 Views)
03-26-2013 01:52 AM in reply to: Alfred.NESWADBA
thanks for your cooperation.i ve successfully installed it by manually starting setup from the extracted files as the extractor wasn't able to extract autorun.inf so i did it manually. thanks a lot.
*Expert Elite*
Alfred.NESWADBA
Message 8 of 8 (592 Views)
03-26-2013 02:00 AM in reply to: vaibhavgpt116
Great to know you got it solved! - alfred -
Alfred NESWADBA
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
