AutoCAD Forum
plotstylestable in MText
2 REPLIES 2
196 Views, 2 Replies
I'm using MText with fields to create a plotstamp within my titleblock. the titleblock is then inserted into a drawing and all fields update with changes(filename/plotdate/username) except for "plotstyles". unless I use blockeditor this field does not update with the change of pentables, which would be helpful when looking at drawings that aren't plotting properly. any and all help is greatly appreciated.thanks.
2 REPLIES 2
pendean
You probably need a unique field in the top file for that. Try it.
in reply to: pendean
If by "top file" you mean the dwg file the border is inserted into, then this is not an option.
I'm trying to make this as simple for my operators as possible.
I created a block with a plotstamp look but have to explode it for the plotstyletable to update.
The field used is -
Field Catagory: Plot
Field Names: PlotStyleTable
Format: None
Field Expression: %<\AcVar PlotStyleTable>%
”Boost
