pdf has the same layer state as these were in autocad file
this pdf is attached as pdf underlay is it possible/ how to on/off the layers of this underlay
Solved by jggerth. Go to Solution.
AFAIK, no. not in Acad. Essentially in Acad a PDF Underlay is a picture, with very little you can do to it in Cad. What i'd suggest is setting the layers on/off as desired in Acrobat Pro (not just reader) and saving to a different name, and then attaching that.
