basically i have two drawing files. Both have the same linetypes. I draw a line (doesn't matter in which file) on any linetype. Then cut and past it into the other drawing. Then for some reason a whole lot of unknown linetypes show up in my linetype manager. when i go into linetype manager and load, they aren't there. So how can one linetype bring in dozens of mysterious linetypes?
These mysterious linetypes aren't in either files linetype manager, or in the load area before i cut and paste.
I've attached pictures to show the linetypes that are showing up for some reason.
Solved by abubakars. Go to Solution.
So creating 2 new drawings based on original AutoCAD templates, then draw a line in the first, copy and paste this line into the second drawing creates that linetypes?
Or is it specific to a specific source-drawing, if so delete all the geometry in that drawing (make a copy before), then try to recreate the issue (draw a line, copy and paste it into a new dwg). If that is now reproducable (so you get the misterious linetypes in the new drawing) then upload the source-drawing here so we can play with it.
BTW: are you using a vertical product like ACA, MEP ...?
- alfred -
I doubt that your drawing contains DGN linetypes which will be carried to another drawing if you copy and paste objects from that drawing to another drawing and the AutoCAD purge command will not purge them.Try the batch tools available as free from http://www.cadmanagertools.com
you can use either Batch-In-Editor or Batch-In-Database to clean up all your affted files and let me know that helps you or not
I had the same issue with my template because i pulled something from a dgn into my template. I had to recreate my entire template from scratch to fix the issue. I hope someone here has a better solution for you.
SORRY, let me be more clear because I didn't quite grasp the complexity of the problem at the times......so some updated details, it doesn't jump from template to templates. doesn't jump from new drawings to new drawings. My templates are clean. It just jumps from existing drawings to existing or existing to new...... So it obviously started from a source drawing.
And there's literally 1000s of drawings on our system with at least a few hundred since this problem occured so finding whats infected or where or when it started is a task that would take a few full days....at least.
I've tried purge, but..... I did the same process i mentioned in the first post, into a new drawing. deleted everything...blocks, shapes, every last entity i could find, all the other linetypes could be purged just not these 'Virus linetypes'.
I don't understand how one linetype can bring in dozens more. that appear not to be connected to anything.
They're not in those .lin file things...
If anybody can tell me is there somewhere else linetypes can load? I've briefly read something about .shx files, can linetypes come from there?
This makes me nervous for the fact it jumps like a Virus, from infected to uninfected with no way to remove it....
And I would attach a CAD file but I don't want to spread this problem...
We work with several different fields and I realize some are using other CAD software, so they could be from microstation or others that I'm not famliiar, so yes some are converted, but it's jump to are plain old regular autocad files. So if that's the case, they're must be files somewhere on the computer. Anyone know where i can look? (it's not in .lin files) Also in response, I'm personally not using any vertical products, other fields we work with might, but we always receive files in Autocad form. they do the converting.
trust me, I didn't believe it couldn't be purged, but it can't, and I don't know why if i draw, lets say a hidden line, then copy and paste, it brings in 10-15 more linetypes into a new drawing.
1. It's not a linetype bringing along another linetype, it's an entity that contains some non-graphical data attached to it, which in turn references something else which in turn references other things, like in this case, some linetypes. There is another thread fairly current on this same topic, let me see if I can find the link.
EDIT: Here it is: http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/Linetype-that-will-not-purge/m-p/4304295#...
2. .LIN files have nothing to do with linetypes in a given drawing. A .LIN file is simply an ASCII container for one or more linetype defintions.
Linetypes don't necessarily require external files. Everything thats needed to define a given linetype is stored in the DWG file, with the exception of shapes from SHX files, or fonts from text placed in the linetype. Even then, the linetype is wholly in the DWG file. So its entirely possibly you won't find a "source file" for these rogue linetypes.
Don't worry *too* much about posting a file. As long as its suitably noted as being problematic it should be OK.
I recently came across the linetype issue when a drawing from outside consultant was passed to draftman from design engineer without CAD manager's knowledge and it started to infect other files and we did not notice untill it became an issue of slow performance and bigger drawing sizes, we had about 1,200 drawings to be cleaned and luckily we used the batch tool expecially the batch process which runs in database, over night in multiple systems to get ride of the DGN linetypes and now our CAD users are instructed to be cautious about slow CAD responses in any drawing and the same to be immediately reported to CAD manager to check and rectify. So it is doable with the team work.
