when creating a polyline with several vertices, trying to track off a vertice of the line being created doesn't work for me, though i don't remember this problem previously. Let me try to describe a little better - in pline, i pick one point, a second, a third, then try to pick the original point to track a line from and I can't, though I can track off a point of an already existing line.
Has anyone experienced this? is there a setting i am missing? any help would be greatly appreciated. thank you.
Solved by samspade. Go to Solution.
answering myself, in case anyone has the same issue. The problem is with the PLINETYPE - needs to be set to 1 or 2, not zero - in order for it to recognize the current pline. it is not an object tracking issue afterall, it is a pline issue because of the object type change with newer versions.
thanks to any and all who spent any effort on this.
