How would I create a libray or palette of multiline styles?
You can go into MLSTYLE and set up your styles, use the save button, accept the default location. Draw an mline on the screen, drag and drop that onto a tool palette. Make copies for the number of styles you have. Edit the properties for each one at the command string something like
^C^C_mline;STyle;pipe;Justification;Zero;Scale;
Give each one a unique name.
When you go to a drawing without the style defined, the first time you pick the tool it will show a dialog asking if you want to load the default file, pick open, proceed.
You could place those in your template so they are already there for new drawings.
good luck
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
