Hello everyone,
I have a problem that whenever i move my cursor over a 3D solid, outlines of the solid stay dashed.
I tried changing the visual effect settings but it doesn't help.
it doesn't only do this in every view (top,side,front) but also when i'm panning around and hover my mouse over any solid.
using the regen command resets the solids so that they don't have the dashed outlines anymore.
whenever i'm panning around and i have conceptual view on, i have to switch from conceptual -> wireframe -> conceptual if i want the solids to look normal again.
This is really annoying and i can't find a solution anywhere.
Solved by Alfred.NESWADBA. Go to Solution.
how is your hardware acceleration set? Try to toggle it and see if anything gets better then (command _3DCONFIG ==> manual tune).
- alfred -
My settings are as follows:
enhanced 3D PERFORMANCE : on
smooth display : off
advanced material effects : on
gooch harware shader : on
per pixel lighting : on
full shadow display : on
texture compression : off
It seems to be fixed now, thanks.
However it doesn't always display the lines as dashed. i'll be back here when the problem occurs again.
