AutoCAD Forum
layers seems to be frezze but they are not
4 REPLIES 4
prizmar
299 Views, 4 Replies
Hi amigos:
layers seems to be frezze but they are not, I can copy text or objeect lines etc but then I can't edit or delete, somebody knows what is going on, please heeelp!.
Thank you.
4 REPLIES 4
pendean
in reply to: prizmar
Post a DWG file and point to the objects in question so that we can try that too.
GrantsPirate
Probably PICKFIRST needs to be set to 1.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Kent1Cooper
I assume you mean that the Layers seem to be locked.  [If they seemed to be frozen, you wouldn't be able to see anything on them to select for Copying, nor for trying to edit or delete them, etc.]  However, I don't have any suggestion as to what may be wrong, since normally you can't Copy things on locked Layers, any more than you can edit or delete them.  I agree that posting a drawing with the problem would be helpful.
Kent Cooper, AIA
prizmar
in reply to: GrantsPirate
Thanks a lot, the pickfirst=1 solve the problem. I guess what caused the problem is eat sandwiches while you press the keyword :D.
”Boost
