Hi amigos:
layers seems to be frezze but they are not, I can copy text or objeect lines etc but then I can't edit or delete, somebody knows what is going on, please heeelp!.
Thank you.
Probably PICKFIRST needs to be set to 1.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
I assume you mean that the Layers seem to be locked. [If they seemed to be frozen, you wouldn't be able to see anything on them to select for Copying, nor for trying to edit or delete them, etc.] However, I don't have any suggestion as to what may be wrong, since normally you can't Copy things on locked Layers, any more than you can edit or delete them. I agree that posting a drawing with the problem would be helpful.
Thanks a lot, the pickfirst=1 solve the problem. I guess what caused the problem is eat sandwiches while you press the keyword :D.
