Solved by KaraB.. Go to Solution.
Solved by hwalker. Go to Solution.
If you have Express Tools installed it's called GATTE
Howard Walker
@KaraB. wrote:
Thanks! I'm trying to use the GATTE command right now. I can't seem to get the hang of it. I assumed that at the block name prompt, I'm supposed to type the name of the block, then I type the tag name, then I type what I want to change the text to. When it gets to the point of selecting blocks, it won't select anything. What am I missing?
Sorry about taking so long to get back to you.
Type in GATTE and then you should select the text in the block you wish to change
eg. you have 10 layout tabs and each of them has a block called attrib2a.
That block has a lot of text fields in it one of them is called year and it has the year 2013 in there already.
Click on the text 2013 and then change that to 2014. It will ask do you wish to change all instances say yes and it will make 10 changes for you.
I've attached a drawing for you to try it out on.
The first layout is the layout as I use it. The second layout is just a load of gobbledigook.
Howard Walker
Though the solution is given to you to update Attribute values, I would like to share here the extended Attribute update methods using LayoutManager which is free and available to download from Autodesk Exchange Apps.
Below are the videos demostrate the commands available in this tool to update the Attribute values.
Update Attributes- group by selection
Update Attribute - by custom values
Update Attribute - by custom values in ModelSpace
Update Attribute - based on another Attribute value
Download the main application from Autodesk Exchange Apps from the link above and upon completion of installation downloading the update from the below link
Hope this will help someone .
Abubakars
So Hwalker,
I came to the forum today for a refresher on this command: GATTE
I just could not find my cheat sheet.
So found my command but then I saw that you had written the word gobbledigook!
I just needed to say sir that you shouldn't use such words since it locks you into a previous era!
Oh, one more thing, I'm left-handed and proud too!
Radar
Well I am 46 in just under a fortnight's time
Howard Walker
