AutoCAD 2013/2014/2015
*Expert Elite*
dgorsman
Message 21 of 32 (1,357 Views)
Re: freezes every few seconds, not hardware problem it seems
09-27-2012 08:06 AM in reply to: knmdk
For commands that can be normal.  Not everything is loaded at start-up, some commands not loaded until they are called hence the slight delay the first time through.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Valued Contributor
knmdk
Message 22 of 32 (1,350 Views)
09-27-2012 11:54 AM in reply to: dgorsman
I've got autosave off, Autodesk 360 off and I'm constantly using those commands. I also notice AutoCAD 2013 becomes painfully slow after a while. I'm doing only 2D linear drafting. Speed gets back to normal once I restart the app. Can that kind of problem (well, problems) be related to graphics card driver?
Active Contributor
Message 23 of 32 (1,345 Views)
09-27-2012 12:49 PM in reply to: knmdk
More like system RAM; it's being cached until you close the program which releases the cache.
How much RAM do you have in your computer?
What's your pagefile settings?
Valued Contributor
knmdk
Message 24 of 32 (1,339 Views)
09-27-2012 01:07 PM in reply to: lfried
I've got 8GB 1600MHz DDR3 RAM. As far as I remember I've disabled swap file after Windows 7 installation. I belive I've read somewhere it's recommended disabling swap file for running Windows 7 from SSD. However I've double-checked the virtual memory setting and it says "Automatically manage paging file size". I'll double-check with the guide I've used previously. In case I did some registry change for swap file configuration.
Another suspecious thing I noticed recently: with this fresh new setup I'm getting like 1-1,5 GB of temporary files (you see it if you use "Clean-up drive" on Windows 7 system hard drive). I only work in AutoCAD, no Internet or other applications on that computer.
Active Contributor
Message 25 of 32 (1,337 Views)
09-27-2012 01:12 PM in reply to: knmdk
You don't want to disable your paging file with an SSD.
When SSD's first were coming out, there were low write limits to the drives so you wanted to disable your pagefile. With todays SSD's, it's actually recommended to leave it with Win7's OOTB settings, especially when you have large amounts of RAM.
Mine runs smoother with Windows-Managed pagefile than without. We've got the OCZ Vertex4 256GB SSD's.
Message 26 of 32 (1,159 Views)
11-20-2012 12:13 PM in reply to: lfried
Still no answer? Mine is doing the same thing. On some of my 3D drawings it takes almost a minute and a half between commands. It's driving me crazy and making the program all but unsuable. :smileymad: I've got my IT guys working on upgrading my 8 gigs of ram to 36 gigs in hopes that will make a difference. Autodesk, if you're listening, please help!
Active Contributor
Message 27 of 32 (1,153 Views)
11-20-2012 12:19 PM in reply to: jody_vaclav
As stated at the bottom of page 2, "Our fix, so far, was a combination of things done on the network and servers since it started around Patch Tuesday. Exactly what was done, we don't know."
Start at page one, post one, and do all the things recommended to us.
*Expert Elite*
Alfred.NESWADBA
Message 28 of 32 (1,150 Views)
11-20-2012 12:20 PM in reply to: jody_vaclav
Do you have an idea what the difference is between your drawings that don't have the problem and the drawings that have not? If you speak about "some drawings" ... are these always the same ones or does it differ like today this drawing was ok and yesterday it was bad?
If you have such "bad drawings" what have you tried with that drawings? Things like _WBLOCK, _AUDIT, _RECOVER (or _RECOVERALL if you have XRefs in it)?
Do you have the option of trying these drawings on another workstation?
Have you tried to use another AutoCAD-profile, if that does not help another chance might be to start Windows with another user-account and try AutoCAD in that context.
A principal question also to your system: what system-specs do you have ... and big question: you have installed the service-pack?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Contributor
Message 29 of 32 (1,147 Views)
11-20-2012 12:22 PM in reply to: Alfred.NESWADBA
Also, 36GB of RAM is way way overkill for an AutoCAD system. I'm using 16GB and noticed no gain coming up from 12GB.
Message 30 of 32 (1,141 Views)
11-20-2012 12:26 PM in reply to: Alfred.NESWADBA
My AutoCAD starts out not having any problem at all ... pretty fast overall, but the more I work on a drawing, the slower it gets. On 2D drawings, it takes about 10 commands before I can percieve the program slowing down. On complex 3D drawings it is almost immediately after I open it up and start working. (please see post: Computer Freezes between commands) I'm in hopes that upgrading my RAM will make a vast difference on my computers performance and I'm keeping my fingers crossed.:smileyindifferent:
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
