Hello
Welcome to the Autodesk/AutoCAD Forums !
Aie, Aie ...
0) I imagine you have an Autodesk Building Design Suite Premium 2014 !?
1) Please open your DWGs in RECOVER Mode and RE-Save ...
Maybe it could solve (or not) some problems ...
2) The bad news : Win 8.1 is not supported by Autodesk !
Only versions 2015 will support offiaclly Windows 8.1 ...
3) Have you the problem BEFORE installing the SP 1 for 2014 ?
4) You are running Win 8.1 Pro x64 but your PC has how much memory in Gb ?
4 / 6 / 8 / 12 / 16 ??
Bye, Pat
Patrice BRAUD
@beppefasano.it wrote:Hi, I have problems with my Autocad2014 sp1 installed on Windows operating system 8.1pro x 64 updated to 2/27/2014.Autocad gives me some errors, closing the file I'm working on.an error occurs using the command copy-paste: "fatal error: unhandled access violation reading 0x026e exception at e3e96db9h"
another error occurs when I try to convert from dwg to pdf:"fatal error: unhandled exception c015000fh at e3face50h",
the latter also happens during normal use of the software and is as follows: "fatal error: unhandled access violation reading 0x00d5 exception at 6f6c6db9h"
I am attaching images if they can help.I am afraid to format my PC because I can have otherproblems with the activation of my Autocad license ( I use win 8.1 Pro x64)
Thank you for the support.regards,marcello.
Windows 8.1 isn't listed as a supported OS: http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/System-...
Hello
The best solution : wait about 1 or 2 monthes ... and upgrade to versions 2015 !
Patrice BRAUD
