AutoCAD 2013/2014/2015
Member
ATKSEC
Message 1 of 5 (1,620 Views)
drawing template created in AutoCAD 2013 not working in 2010-12
1620 Views, 4 Replies
02-13-2013 09:28 AM
Hi
I was wondering if you could help me with an issue I have. I originally created a drawing template in AutoCAD 2012 that was used in AutoCAD versions 2010 - 2011 and worked fine. After recently transitioning over to AutoCAD 2013 i have made modifications to the dwt file and it no longer appears to open/work in 2010 or 2011?
Has something changed in 2013 that means the templates won't work in older versions? Is there a setting I can change? I've never had this issue before until now? Any help would be greatly appreciated as I don't want to have to create different dwt files for different AutoCAD versions?
Distinguished Contributor
cadwomen
Message 2 of 5 (1,619 Views)
Betreff: drawing template created in AutoCAD 2013 not working in 2010-12
02-13-2013 09:31 AM in reply to: ATKSEC
Dear Sir ,
mayby it better to read the manual bevor ....
http://docs.autodesk.com/ACD/2013/ENU/caas.html?url=%2Fcaas%2Fknowledgebase%2Fadsk%2Fservlet%2Fps%2F...
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
JGerth
Message 3 of 5 (1,610 Views)
Re: drawing template created in AutoCAD 2013 not working in 2010-12
02-13-2013 09:40 AM in reply to: ATKSEC
yea, the drawing file format changed between 2012 and 2013, just like it did from 2009 to 2010.  Typically, autodesk reworks the file format every third release.  And the only difference between a dwg and a dwt is the last letter of the file extension.
To work around it, you can do a SaveAs to a dwg file, using the 2010 format choice, and then in Windows rename the .DWG to use a .DWT extension.
Valued Contributor
itbemedg
Message 4 of 5 (1,602 Views)
02-13-2013 09:44 AM in reply to: ATKSEC
So save your new template as a drawing in an older format then rename its extension to .dwt.
By default, ACAD 13 cannot be opened by previous versions - you must purposely save it to an older version.
Member
ATKSEC
Message 5 of 5 (1,598 Views)
02-13-2013 09:47 AM in reply to: itbemedg
Thanks for your responses, I had missed this little caveat when reading the online help and I have now managed to get it working. I understand Autodesks addition of file types every 3 years but seems a little strange for you not then to be able to saveas dwt's in an appropriate format too as you can with dwg. Anyway thanks.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
