I work with both .dxf and .dwg files regularly. When I go to save a .dxf file (_QSAVE), I am always asked if I want to convert to .dwg...it's as if I'm being "persuaded" to switch to .dwg. Is there a way to disable this? Thanks.
Try setting your default file type to DXF
Without this set, I only get prompted to save as DWG at the first Qsave and when I close the drawing.
Are you being prompted each and every Qsave?
If I change that setting, won't it basically reverse my problem?
Now that you mention it, I only get prompted on the first _qsave. However, I have to open up a large number of .dxf files and work on them quickly then close them, so it's still an annoyance.
Hy
so there are tool to make dxf out of dwg as a batch , as long as you go to lunch or every friday evening
cu cw
