AutoCAD Forum
disable 360 menu
9 REPLIES 9
Message 1 of 10
ferriscad
7535 Views, 9 Replies
disable 360 menu
How do I disable the 360 menu?
I actually purchased this software for work, not to tweet or facebook.
9 REPLIES 9
Message 2 of 10
DarrenP
in reply to: ferriscad
uninstall autodesk 360 from the add/remove programs
DarrenP
Message 3 of 10
ferriscad
in reply to: DarrenP
What about this?
Please see attached.
Message 4 of 10
nestly2
Before you do that, just be aware that you may end up having to re-install 2014 (&13) due to a bug in the installer/uninstaller
http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/How-To-Install-AutoCAD-2014-WITHOUT-Autod...
*edit*  the link above only applies to AutoCAD, I do not know about what dependencies inventor has with 360
Message 5 of 10
DarrenP
in reply to: nestly2
i haven't had an issue yet since i uninstalled autodesk 360 using the add/remove in windows
DarrenP
Message 6 of 10
ferriscad
To risky, I've been seeing some bad uninstalls with this release, meaning that I'd have to reformat my pc to remove the 360 spam bar.
Message 7 of 10
maxim_k
If you just want to remove 360 from Ribbon:
You can also disable synchronization in Options.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 10
pendean
I removed adsync/360 from R2014 to solve a nagging app crash whenever I closed AutoCAD (a hunch) and there are no issues with R2014 or any of the other modules. It runs great.
Anyone stating otherwise is just blowing smoke.
I went through Windows Control Panel to remove it.
Message 9 of 10
ferriscad
in reply to: pendean
Yes!
Uninstall from the control panel got rid of that crap with no problems, I guess the problems I heard about were from using the uninstall utillity.
Thanks!
Message 10 of 10
sssteve72
I was having the 'cannot write to internet cache' message.  Suspecting 360 as a possible cause I just used MSCONFIG and unchecked 360 from the startup menu.
This way I didn't uninstall anything and if I ever need it, then it is still there.
For those not familiar here is how (This is for Windows 7)
Close out of all programs as you will be restarting your computer (though you can delay the restart).
Click your start button and in the search bar at the bottom of the menu type in MSCONFIG.  It will find only one program msconfig.exe.  Click on that and and then click on the startup tab at the top of the dialog window.  Scroll down until you find Autodesk 360 and uncheck it.  Click ok and then select restart now from the menu that appears.
After I restarted and loaded Autocad the 'cannot write to internet cache' message disappeared.
Custom Build with Win7 Pro 64Bit SP1
Gigabyte Tecohnology Co. X79-UD3
3.60 gigahertz Intel Core i7-3820
16GB GSkill Ripjaw Z PC3 2133 PC17000
PCI-E ATI FirePro V7800 2GB 256bit
ATA SanDisk SDSSDX24 SCSI Disk Device (256 GB)
Dell 2001FP, 2407WFPHC, ASUSVN289 in Triple monitor setup
Question - Are you the Common Denominator?
”Boost
