A few weeks ago I upgraded form AutoCAD 2006 to 2014. In 2006 there was no way in native AutoCAD to have any dimensions automatically put on the DIM layer regardless of the current layer and then, after the command, return back to the current layer. For example, if the current layer is VIS and a dimension is created, that dimension would be put on the DIM layer; when the dimension command is completed, layer VIS would still be current. In 2006 I had to install a special .lsp routine to do this.
This seems very basic to me. Doesn't just about everyone put all their dimensions on a seperate layer? Shouldn't AutoCAD do this natively?
So, when I got 2014 I thought for sure dimensions on DIM layer would be a feature. It doesn't seem to be; at least I can't figure out how to do it if it is. Am I missing something? Is this possible, and, if so, how? If not, does anyone have a suggestion of how to accomplish this? (the .lsp routine I used in 2006 isn't working consistently well in 2014 and I can't figure that out either-maybe it's time for me to retire!)
I've made myself a tool palette with all the dimension commands on it. I've also set it up so they are automatically put on a layer called dimensions. If this layer doesn't exist Autocad creates it.
The layer that I'm on before I put the dim on does not change after I've finished putting the dim on. You might want to try going down that path.
Howard Walker
No lisp or customization needed with Tool Palettes. Just drag dimension (that's already on the correct layer) onto the tool palette, and after that, any dimesion started from the Tool Palette will automatically be placed on that layer regardless of which layer is current.
I've attached my dimensions XTP file (just change the .txt extension to .XTP). I only use LT so no lisp routines, but it should work no problem in full Autocad
Howard Walker
Just use DIMLAYER Command in command line and change layer for your dimensions
