I've had this problem with a number of drawings of mine. But it seems to be only drawing-specific.
When I create a new dimension using the DIMALIGNED command, the dimension is created, but as a number of different objects. The extension lines, leaders, and dimensions are all different objects, as if they had been exploded already. Any idea how to fix this problem?
Solved by steve216586. Go to Solution.
In the drawing which is giving you problems set Dimassoc=1 or 2. This system variable is saved per drawing. I like 2.
