AutoCAD Forum
dimensions created as seperate objects
2 REPLIES 2
camshaft89
299 Views, 2 Replies
I've had this problem with a number of drawings of mine. But it seems to be only drawing-specific.
When I create a new dimension using the DIMALIGNED command, the dimension is created, but as a number of different objects. The extension lines, leaders, and dimensions are all different objects, as if they had been exploded already. Any idea how to fix this problem?
2 REPLIES 2
steve216586
in reply to: camshaft89
In the drawing which is giving you problems set Dimassoc=1 or 2. This system variable is saved per drawing. I like 2.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
camshaft89
Thanks for your quick reply! Worked just fine 🙂
”Boost
